Hello Everyone,
What is the reason for making a high internal temperature alarm on Lynx Shunt?
Any recommendations? Might it be loose connections or so?
Thanks in advance
Hello Everyone,
Thanks in advance
Loose connection, poor ventilation especially if something has fallen over the slots or the fuse starting to get hot under high current flow. There was a case on here of someone with an overheating Lynx Shunt because their fuse was rated too close to their normal continuous current, the fuse should be 25% higher than max continuous current demand.
47 People are following this question.
Lynx Shunt VE.Can installation
hey all, cant get ve bus to appear/be detected
LYNX VE.CAN-Shunt: Location of the configurable onboard relay
Will the Fuse LEDs on Lynx Distributor illuminate without the 4-pin cable supplied with unit?
Lynx Shunt VE.CAN Battery Status PGN for Batt Instance 0 not transmitted.
