manuegr avatar image
manuegr asked
Updated MultiPlus 12/3000/120-50 120V Firmware and now not charging
I updated the firmware on my devices. After i completed the update on the MultiPlus 12/3000/120-50 120V, now it only discharging. I checked all the settings and redid the firmware update and no change. Can somebody please help.
Multiplus-IIfirmware update
derrick thomas avatar image
derrick thomas answered ·
Did you check the multi configuration with veconfig
nickdb avatar image
nickdb answered ·
As documented (and warned) in the process, the config is wiped when an update is done to an inverter. Did you follow all the instructions and reload the configuration?
pwfarnell avatar image
pwfarnell answered ·
Step by step instructions for doing this via VRM linked here
https://www.victronenergy.com/live/venus-os:remote_ve.bus_firmware_updates
