Interesting I've just updated my Cerbo GX to v3.22 and now can't see my AC Loads on VRM Portal is there a setting I need to change?
A firmware update should not have changed anything with communication on the regular running of the system
Just check your MK3 (under device list - inverter) driver is not asking for an update. Not sure from what FW you upgraded from.
But if anything, roll back.
under settings select your inverter scroll down and upgrade the mk3 were asked
Not sure if it's your issue, but you update the MK3 USB in the Multi settings page if it asks you to, see the below thread with pictures:
Guys I'm still having issues with my VRM not showing AC Loads after Cerbo Update
Venus Firmware v3.30
Multi Firmware v508
Is there a setting I need to change?
Straight answer. No. Unless something else is not right.
Is it the AC loads on the inverter or do you have an energy meter?
Does it show AC input at all?
As soon as I reload v3.00-14 the VRM starts logging again with no issue
I'm only updating for the few changes that have been made to the latest firmware since the v3.00 is nearly 12 months old
I'm beginning to think I should never update firmware on any Victron products reading through a lot of comments regarding updates most people seem to have issues one way or another with most of the Victron gear
How is your inverter connected to the GX?
Do you have a mk3 connected at the same time?
Firmware updates work, when they don't there usually is a good reason which is generally human error.
Issues can occur but they are generally rare and fixed fairly quickly.
This combination works, so something else is off.
Please add some screenshots, and show how the system setup is on the GX, any meters installed or CT's?
Inverter permanently connected via mk3 to Cerbo.
No meters or CT's
All I've done different is a firmware update.
This will give different functionality.. "via mk3".
Use a VE.Bus connection with a RJ45 (Ethernet) cable. Put the MK3 dongle into storage.
After running with mk3 permanently in place for the last 2 years it's the last thing I would have thought of
I must have been lucky with previous Firmware.
Remotely Update VE.Direct Firmware
VictronConnect manual / Firmware updates
Updating a Victron Smart Solar MPPT Charge Controller with Victron Connect
VictronConnect configuration guide for VE.Bus products - Firmware Updates
51 People are following this question.
