coalen avatar image
coalen asked
Node-Red not Loading via VRM - It Attempts but Stops
I am experiencing Node-Red not loading from VRM Dashboard as of past two days. I rebooted the Cerbo with no success. Could this be related to the back end issue per the message we have been receiving on the VRM Dashboard?
Any recommendations?
Node-RED
coalen avatar image coalen commented ·
Any feedback on Node-Red not loading?
Dirk-Jan Faber (Victron Energy) avatar image
Dirk-Jan Faber (Victron Energy) answered ·
You could try to restart node-red in safe mode and test if that works. If so, it probably is one of the flows that has the problem.
The logging (under /var/log/node-red-venus/current) should give some more insight on what the cause is.
coalen avatar image
coalen answered ·
Hello @Dirk-Jan Faber (Victron Energy),
Thank you for the reply. Safe Mode was enabled but Node-Red did not run. What is required for me to access the logging path you suggested?image-3-15-24-at-907am.jpg
The procedure is described in this document: https://www.victronenergy.com/live/ccgx:root_access Though it does require some linux knowledge (which has quite a steep learning curve).
