I see some tags in VRM which I cannot remove. Also in the Tags menu, it is empty so impossible to remove from there. How do I get rid of these tags?
@MarceldB
Settings/Tags/ then delete tags as required by selecting the 'X' next to the tag you want to remove.
If the tags are showing in the dash board but not appearing in the tag menu list, then re-add them so they do appear in the tag menu, then delete them. That should clear them from your dash board.
63 People are following this question.
