happycloud avatar image
happycloud asked
What busbar to use to join dual parallel multiplus AC outs
I am building a parallel multiplus and wondering what people generally use to join the outputs before going to panel (which is 30ft away). None of the victron busbars I see are rated for that voltage and all diagrams generally just show nothing. I am using dual 24/3000/120V multipluses
multiplus in parallel
Alexandra avatar image
Alexandra answered ·
@happycloud
That will be because AC distribution is based on local regulations.
Look for something like this based on your amps needs. Or this.
FYI though the longer your AC cable it the loads balance better on parrallel set ups so don't join them too close. In the three phase parallel manual it recommends using slightly lower gauge cable and a little bit longer.
happycloud answered ·
Thanks - but these are not standalone and meant to be in a panel which is a bit overkill to join two wires together
Yeah. Just examples. Fairly certain you can look for what you want.
