i am looking to create a Victron-raspberry pi...
First question
Does a raspberry pi communicate or display to the VRM portal
Does anyone has a list of hardware require for the Raspberry pi
Tks
First question
Tks
Yes, RaspberryPi communicates with VRM the same as any Venus device.
You have the remote console too which is accessible on LAN IP address or via VRM.
Required hardware depends upon what equipment you want to connect to the RaspberryPi.
Almost everything must be via USB, so VE.Direct devices (BMV, most MPPT's, some inverters) will each need a VE.Direct to USB dongle: https://www.victronenergy.com/accessories/ve-direct-to-usb-interface
VE.Bus devices (MultiPlus, Quattro) will need MK3 to USB dongle: https://www.victronenergy.com/accessories/interface-mk3-usb
Run your RaspberryPi from a good power supply, the official RaspberryPi PSU is a good one.
How to change the Owner of a VRM installation
Raspberry Pi running Victron’s Venus firmware - Blog Post
Venus OS Large image: Signal K and Node-RED - Install
raspberrypi install venus image
11 People are following this question.
