marceldb avatar image
marceldb asked
EV charger does not update firmware
I received my brand new EV charger with display recently. It has connected to VRM and is visible in Cerbo GX. When I try to update the firmware from 1.21 to 1.27, error 1302 appears. In addition: the charger webpages does not offer the option to upload the firmware.
The WIFI signal is pretty strong, the Cerbo has a LAN ethernet connection.
How to solve this?
firmware updateev charger
Lucian Popescu (Victron Energy Staff) avatar image
Lucian Popescu (Victron Energy Staff) answered ·
Can you try a few times please? If it's not working, please contact me.
The option to upload firmware through the webpage was added in 1.23 if I remember correctly
5 comments
marceldb avatar image marceldb commented ·
I tried it over and over again, during several days. So if you can help me with this, I would appreciate it
dennibu avatar image dennibu marceldb commented ·
Ich musste auch ein Update von 1.21 auf 1.23 durchführen. Leider gibt es bei 1.21 weder die Möglichkeit per Webinterface noch Bluetooth. Ich musste es 8-10 Mal ausprobieren, bis es endlich klappte. Ab 1.23 ist dies problemlos über das Webinterface möglich.
marceldb avatar image marceldb dennibu commented ·
Ist ein Update von 1.21 nach 1.23 leichter durch zu führen?
I don't know. I only had to update 2 times from 1.21 so far and that was 2 years ago. Since then I have had at least 1.23 and I have always done it via the web interface.
However, the problem is known and persistent repetition was always the solution.
How can I contact you?
kennybuntinx avatar image
kennybuntinx answered ·
I have exactly the same issue going from 1.27 to 1.28 ...same thing - it is not network related .
please advise @Lucian Popescu (Victron Energy Staff)
So you cannot update from VRM? If yes, please have a look here: https://community.victronenergy.com/questions/276002/fw-update-ev-charger-failed.html?childToView=276061#comment-276061
Please keep me posted.
david-callebaut avatar image
david-callebaut answered ·
same here
Fout
De 2 weg communicatie service van de site reageert niet meer. Controleer de internet verbinding en/of probeer opnieuw
Error: 1302
Yes, please update using the method described in the other post ( link above)
mito555 avatar image
mito555 answered ·
Same problem here 1.27 --> 1.29. I can't find the download file (I'm not a Victron professional) so I can't install it through the website of the EV Charger. I don't have any problems with SSID.
You can create an account, it is simple and free. And you will be a professional after :)
mito555 avatar image mito555 Lucian Popescu (Victron Energy Staff) ♦♦ commented ·
Ha great :-) I'll try that!
Martin Opdebeeck avatar image
Martin Opdebeeck answered ·
Same Issue Here. 1.27 >>> 1.28 however the update worked yesterday on site of my son . But here errors only on EVCS update. Cerbo GX update and MPPT updates worked perfectly
Known issue, it will be fixed in Venus OS v3.31
Martin Opdebeeck avatar image Martin Opdebeeck Lucian Popescu (Victron Energy Staff) ♦♦ commented ·
Great !
Thks
