I bought a Victron EV charger and when I connected it to the single-phase power the screen keeps turning on and off as seen in the video.
Is it possible that it came defective? Or is there something I'm doing wrong?
https://community.victronenergy.com/questions/271305/ev-charging-station-system-data-error-after-upgrad.html?childToView=312180#answer-312180
hi, please check my answer on the link above, it's the same issue
If you need my help, please contact me!
Hola Lucian, creo que no es el mismo problema. Me sale un mensaje de "Cargando" y la pantalla se apaga y se enciende.
¿Es un problema de pantalla?
¿Debería funcionar el cargador? Es decir, ¿debería poder conectarme al Cerbo?
Todavía no he conseguido conectarme al Cerbo y el cargador no funciona.
Gracias
39 People are following this question.
