drofwaves avatar image
drofwaves asked
Need help choosing a charger.
Hello, my boat is an offshore cruising sailboat currently configured as follows:
5.0 KW 120V Northern Lights Generator
50 Hp beta with 120a Balmar Alternator and Voltage Regulator
Victron 12/50 charger
Vintage Battery Isolator
400 watt wind generator
4xgroup 31 Lifeline AGM house bank
1xgroup 31 Lifeline AGM start
no solar
Presently I have no means other than system voltage to monitor power distribution. I am planning to install a fresh set of AGMs and would like to set the foundation for a lithium conversion next set of batteries.
My plan is to install a smart shunt, battery isolator, Cerbo and a new charger.
Any advise would be appreciated,
thanks,
scott
battery charging
JohnC avatar image
JohnC answered ·
Hi @DrOfWaves
What your system seems to lack is a Multiplus. A charger with an inverter thrown in as a bonus. :)
Presumably you need the genset for your ac loads, but a Multiplus would change that. It could serve ac needs while the batteries are still capable, then when in need of charge would use the genset, which will also passthrough to serve ac loads at the same time. And the genset can be set to cruise at it's optimum power output, saving fuel and running time too.
The Cerbo would then have something to do, it's somewhat lost without a Multiplus (or Quattro, which has 2x ac inputs).
120V ac isn't in my comfort zone, but check the Victron website for available models and plenty of info. You'll likely have more questions, just ask..
