Joost avatar image
Joost asked
Multiplus II error lights
We have converted a lifeboat from a diesel engine to an electric motor and we are having problems setting up the Multiplus. We are definitely not pros so any feedback is very welcome!
We’ve got the following setup:
- Smartshunt
- Cerbo GX
- BMV 700
- Multiplus II 48/3000
- 4 LiFePo4 12,8v 200ah batteries
Tried to setup the inverter. The inverter is in low battery alarm when switched on. Batteries are 52,3V. Connecting the Multiplus with HP Envy Laptop via the MK3. The laptop updated the firmware and says it’s setting up a connection after which a ‘help’ button appears on screen. When connecting the multiplus to shore power we get the error message as shown on the picture below:
Tried the following:
- Connected to both VE.BUS ports
- Tried DC power alone, and 230v shore power
- Tried different CAT cables, including one from Victron
- Checked whether we installed the USB driver
Multiplus-IImultiplus ve.buswiring diagramlifepo
errormultiplus.mp4 (3.7 MiB)
nickdb avatar image
nickdb answered ·
If you open the victron toolkit app, it has most of the LED sequences and their meaning.
delf67 avatar image
delf67 answered ·
Are you using Victron Connect or VEconfig software?
Have you put a multimeter on the Multiplus battery terminals or is the 52.3V from the shunt?
MultiPlus-II Product page
MultiPlus-II Manual
MultiPlus-II 230V Datasheet
VE.Bus Error codes
