P Markowski avatar image
P Markowski asked
Victron Multiplus II 12/3000/120-32 MCB's on 16A shore vs Power Assist
Hello, I am switching to lithium battery bank on my sailboat and I am adding the inverter (Victron Multiplus II 12/3000/120-32), I have 16A shore power connection which will be connected through VDI-16 galvanic isolator and 16A MCB (B16) with 3x2.5mm2 cable to Multiplus AC input, then I am planning to connect AC output with 3x16mm2 cable to boat AC panel which is currently secured with 16A RCBO and MCBs, question is should I upgrade those to 32A (because of Power Assist function)? I am afraid that 16A MCBs will trigger when Power Assist will turn on.
Multiplus-IIfusespowerassist
MultiPlus-II Product page
MultiPlus-II Manual
Multiplus-II GX Online Manual
MultiPlus-II 230V Datasheet
VE.Bus Error codes
Fuses & fuse holders Product Page.
