Juan van der Merwe avatar image
Juan van der Merwe asked
Grid reading of ET340 energy meter issue
I am experiencing the following with an ET340 energy meter and have found the following issue that is similar.
Et340 grid meter values issue. ESS not working correct - Victron Community (victronenergy.com)
The setup is 3 10KVA Quattros with Cerbo GX and ET340 energy meter with lithium battery as well as solar array.
The energy meter is reading an export on L1 but an import on L2 and L3 that amounts to the export. Grid setpoint is being met but the summary suggest the system is exporting. See images below for reference.
ESS setup with Multiphase regulation set to Total of all phases.
@Daniël Boekel (Victron Energy Staff) Not sure if tagging you may help or if you can guide. Seems to be a few issues that are similar to this.
Energy Meter3 phasefeed-in
