ngknick avatar image
ngknick asked
Remote console failed to connect, enabled but not online. Can connect via LAN
Update: LAN connection works. Test links from Victron work, so not firewall related. GX enabled but not online. Data logging working. See add'l screenshot.
Have successfully used remote console but currently getting connection error. I can connect to VRM application and monitor settings/ turn on and off the inverter. So two-way communications seems to be enabled and working. I've tried resetting the password, rebooting the GX, updating firmware. Have read plenty of other threads of people having issues, trying to avoid the last solution I found of factory resetting the GX since I've had it working previously.
I noticed the VRM console says enabled but not online. However when looking at the GX touch device it shows online and enabled? Does anyone have troubleshooting tips or ideas? I do have an MK3 that I keep plugged into the multi if that's causing any issues (nothing connected to the usb end). I also tried connecting to the VRM remote console without the MK3 plugged in and still could not connect.
Update/Edit: I can access both Victron URL's ( https://vncrelay.victronenergy.com & https://vncrelay2.victronenergy.com/) from multiple devices with no issue. Will try from LAN and report back.
VRM online portal settings show ONLINE and Stored Reports 0
cerbo gxremote console
Alexandra avatar image
Alexandra answered ·
@NGKnick
Did you set or disable the password when you enabled it online? It does also require reboot afterwards.
More troubleshooting steps here.
ngknick avatar image ngknick commented ·
thank you - yes, enabled password - then reset and was able to connect with password enabled. Fast forward a few weeks, and am unable to connect.
Have been using a T mobile hotspot (with Google Fi data only sim) the whole time if that plays a factor. Have seen threads where that may be the issue, but I was able to connect before.
