I have MultiPlus-II 12/3000/120-50 120/240V running Firmware version 506. Im trying to use Ignore AC Input Virtual Switch to prioritize solar consumption when plugged into and paying for shore power. The Virtual Switch will work as long as the loads are on L1. If the loads are only on L2 and higher than load condition the switch will not respect the loads and drop the AC connection. This has resulted in system overloads shutting down the system. How do I insure the loads on L2 are included in the load calculation?
![ignore-ac.png](/storage/attachments/70771-ignore-ac.png)
