2024.
Don't tell me that there still isn't a way to remotely configure the system remotely on a Mac?
2024.
You'll need to be more specific, I think. What system? What software are you using? What are you trying to remotely configure?
Plenty already posted on the subject and available via search.
You can remotely push/pull config files fine via a mac, do it often enough
You can locally use victron connect for most changes.
It's just the veconfigure toolset that will not run unless you use parallels or similar, or a remote desktop in windows to build the file.
It would be nice to run it natively as a mac user myself, but dev work is going into VC as a replacment, eventually, and I suppose mac's marketshare is still relatively small.
It is tier 2 with most, if not all, software vendors.
Remote Console on VRM - Troubleshooting
42 People are following this question.
