mmx01 avatar image
mmx01 asked
Victron EasySolar II + MultiPlus II in parallel 1 phase operation
EasySolar II shows as combination of few budling blocks and the inverter reports as Multiplus II 24/3000. For parallel single phase operation, is it compatible to connect MultiPlus II like this one: PMP242305010 with EasySolar? The latter has got PN: PMP242307010.
Both are 24/3000/70-32 with new revision 010 but then part of PN: 3050 does not match 3070.
Want to avoid "we will not talk to each other" software wise. I am looking for single phase parallel operation for increased VA capacity for periods of peak usage with AC, Kettle, Boiler etc.
Regards,
Mariusz
multiplus in parallel
snoobler avatar image
snoobler answered ·
marekp avatar image
marekp answered ·
@mmx01
I have ES-II 48/3000 and MP-II 48/3000 and they work well in parallel.
If HW Rev # is the same there should be no problem.
mmx01 avatar image mmx01 commented ·
Thanks! I ended up getting another ESII and put them in parallel. I will wire 2nd string of solar into it.
Also pricing is interesting MPII 24/3000VA is around 1100 eur, ESII is around 1300 eur but it includes 250/70 for 600 eur and GX is probably another 200 eur. So this unit is IMO really good value for money.
I needed to disconnect 2nd GX and rewire smartsolar ve.direct from the slave into the main unit but works good otherwise.
marekp avatar image marekp mmx01 commented ·
@mmx01 You will have to disable on GX unit.
mmx01 avatar image mmx01 marekp commented ·
Yes I know and I did it by disconnecting power to the board. Also you need to wire built-in MPPT ve.direct external to the other GX unit via ve.direct to USB cable. Otherwise built-in MPPT production of the second unit is not reported.
