dirkj avatar image
dirkj asked
VE.Bus System Battery Temperature Reading
Both nodes "VE.Bus System" and "System" have a "Battery Temperature" measurement. Both measurements always return "null". There is a MultiPlus II connected to the system with a battery temperature sensor connected.
Any suggestions?
Thank you in advance
Node-RED
Alexandra avatar image
Alexandra answered ·
@DirkJ
Do you have a temperature sensor connected to the temperature input on the inverter?
@DirkJ
Does the temp sensor report its reading to the GX? Check under MP in device list.
dirkj avatar image
dirkj answered ·
Sorry, but I can't find any temperature field in the MP device on GX.
In "Alarm Status" "Temperatur Sensor" shows "Ok".
It's internal temp sensor cannot be read. But the battery temp sensor can be. It reports to the VRM and if working/connected correctly you can see it in under the Multiplus in the devices menu.
Alexandra avatar image Alexandra ♦ Alexandra ♦ commented ·
dirkj avatar image
dirkj answered ·
Unfortunately there is no Battery temperature:
