88hardy avatar image
88hardy asked
Compact 12/1600/70 and 200/200A GX
I have a Compact 12/1600/70 and a Cerbo GX and also a 200/200A GX panel, at the moment the 200GX connects to the Cerbo and that in turn connects to the Compact multi. With this setup I cannot remotely switch on the inverter. If I connect the 200/200A GX directly to the multi and the Cerbo GX to the 2nd port on the multi, will I then be able to remote control the multi through the app?
Thanks
remote console
No, with a DMC connected the control from a GX device is disabled.
Kevin Windrem avatar image
Kevin Windrem answered ·
No you can not have two inverter/chargers in the same system under the same GX device. Multiple units are allowed only when identical units are configured in parallel and/or muilti-phase.
