jacko avatar image
jacko asked
Help with victron lifepo4 batteries
Hi I am using victron lifepo4 batteries for the first time we have 4 25.6 200ah batteries being used in a 48v system, in the manual there’s a diagram in a bit confused by it says “do not interconnect the mid points” yet shows them connected. I don’t know if it’s referring to the bms cables or the battery links ever way the diagram shows both joined. I’ve attached the diagram any help would be appreciated. Thanks jack
Lithium Battery
wkirby avatar image
wkirby answered ·
Hi Jack
In that diagram, the midpoints are not interconnected.
There are three midpoint links between each series string of batteries (each pair of batteries), but those midpoints are separate. None of the midpoint links are connected to another one.
jacko avatar image jacko commented ·
Arhh I see what you mean I was reading it wrong haha. Thanks for your help!
