Is it possible to make my old (3 years) EasySolar 24/3000 work with say MultiPlus 24/3000 to give me safely more power in my off-grid 24v 360ah lifepo4 system? Or anything else?
I have paralleled an Easysolar 48/3000 with a Multiplus 48/3000. Running now for close to 4 years. But, you must make sure microprocessor's are the same. Check the first 4 digits of the firmware, this must be the same.
There is a lot more to paralleling Multi's. Victron has comprehensive documentation that you must study. In hindsight, I should have just bought a larger Easysolar to begin with. The amount of work and costs invovled (cables/ breakers etc) should not be underestimated.
122 People are following this question.
