Alex Pescaru avatar image
Alex Pescaru asked
Bug report: individual MPP operation mode reporting not working
Hi developers,
Multi RS Solar and Modbus TCP
MPP operation mode (general) 4543 reporting OK
MPP operation mode (individual) 4605, 4606 reporting NOT OK.
For example 4543 reporting 2 (MPP active) and in the same time 4605 and 4606 reporting both 0 (MPP off).
Alex
bug reportMulti RS
Hi @Alex Pescaru
What is Venus OS version?
Kind regards,
Thiemo van Engelen
Thiemo van Engelen (Victron Energy staff) avatar image
Thiemo van Engelen (Victron Energy staff) answered ·
Hi @Alex Pescaru
In version 3.14, the MPP information per tracker is not available internally in Venus OS and then Modbus TCP returns 0.
Kind regards,
Thiemo van Engelen
Alex Pescaru avatar image Alex Pescaru commented ·
Hi developers,
Thank you for clarifying it for us.
Maybe on the "Document Versions" tab of the "CCGX-Modbus-TCP-register-list.xlsx" file, it worth mentioning, besides revision number, the minimum version of the Venus OS for those revisions to work.
Thanks again!
Alex
Hi @Thiemo van Engelen (Victron Energy staff) , @mvader (Victron Energy)
Kindly kindly please, can I ask you something?
On the future, can you please add one more state on DBus, for the "MPP Operation Mode" (/PV/x/MPPOperationMode), like "3=Scanning"?
In this way it will be easier on send_data() from vrmlogger, to handle the MPP scans and delay endpoint.send() during MPP scans, like you've done it on send_hourlydeltas()
Thank you!
Alex
Alex Pescaru answered ·
Now in 3.20 reporting OK.
Thank you!
It's the last official/release version, 3.14
Alex
And if we are still here, also:
2901, ESS Minimum SOC is always reading 100 (10%) no matter what you set in ESS setting page at Minumum SOC.
2903, ESS BatteryLife SoC limit (read only) also reading all the time 100 (10%), even if is set to "WITH BatteryLife)
2900 ESS BatteryLife reporting all the time 1
2902 ESS Mode reporting all the time 1, no matter what you set in ESS setting
Thank you
Alex
LE:
Now I see that those above are "com.victronenergy.setings", not "com.victronenergy.multi" and as Multi RS has a "hybrid" ESS, then they don't have how to show correctly.
Still, can be reported and set?
Thank you again!
Mutli RS Solar Datasheet
Mutli RS Manual
