We changed CCGX with a Venus on this site
Old history data has been retained - however - since 2019-07-26 there is no data on the advanced tab. Date / time on Venus is set correctly.
Dashboard data is perfect. Installation (21159)
@Eujean Hugo Just checked your installation. You have only widgets enabled for a device that is not present anymore (VE.Bus instance number 0, while your current system has instance number 261). If you delete the old device from the device list and select widgets from the new one, it will all start working again.
9 People are following this question.
