Hi Everyone,
Does the temperature sensor of the Multiplus II 5000 measure temperature if it is not conected to the negative battery terminal (temperature sensor is left floating)?
Thanks!
Hi Everyone,
Thanks!
Yes it will measure the temperature around it, the lug is actually not an electrical connection.
The external temperature sensor for the Multiplus is glued in the cable eye, and is fully isolated. The cable eye can be mounted on to the negative terminal of the battery, or on to the negative busbar of the battery installation.
As far as I know certain battery types require a lower charging voltage during warm operating conditions and a higher charging voltage during cold operating conditions. In this case you need to do temperature compensated charging with the Multiplus, needing the externe temperature sensor.
Victron temperature sensor disambiguation table - which product supports which sensor
111 People are following this question.
