renejk avatar image
renejk asked
Venus GX relays , can I use ML-RBS 7700 latching relays ?
I am looking to use the Venus GX together with a 712smart to shut down loads and charge busses based on voltage to prevent over- under charge of the batteries, can the Venus GX do this ?
Furthermore , if this is possible can the Venus GX operate latching relays ?
thanks
Rene
Venus GX - VGX
Paul B avatar image
Paul B answered ·
The venus / CGGX units relay state in its standard off the shelf setup is on or off, most latching relays only require momentary power. so to use a latching relays you would need to add some sort of timer setup to run latching relays instalation
renejk avatar image
renejk answered ·
thanks Paul !
I was afraid of that , so back to the drawing board
