I get the current from battery monitor but the numbers are always positive, even when the battery discharges. How can I get the sign to distinguish beween charging and discharging
It looks like the value is represented as a signed 16 bit number.
I would use a function, containing:
if (msg.payload > 2**8) { msg.payload -= 2**16 } return msg;
It checks if the number is larger than 2^8. If so, it subtracts 2^16 from the value.
49 People are following this question.
