jakes7196 avatar image
jakes7196 asked
VRM Feature suggestion
Two months ago I disconnected/removed the battery from my travel trailer for winter storage. However, the VRM dashboard currently shows the battery percentage at 65%, which is the last known value. There is the Last Updated time field on the dashboard, but a configuration setting for clearing VRM display values after a user input number of days or hours would be helpful. I have various temperature sensors that also show the Last Updated field and outdated values. Clearing these values would also be helpful.
VRM
matt1309 avatar image matt1309 commented ·
Hi @jakes7196
If you're desperate for the feature I imagine you could write this yourself. The way i would do it is have a node red instance listen to the MQTT topics of the data points you want to reset to 0.
Then have a node red function that if that MQTT topic doesn't have an update after your user input number of days/hours then node red sends 0 or any defined value to that same MQTT topic. I believe that will accomplish what you're after.
I know you were just requesting the feature but there's a work around if you want to implement yourself/in case it's not added to vrm natively.
