sedlacek avatar image
sedlacek asked
MultiPlus 500VA - 1600VA & starter battery charging & Smart alternator
is it possible to charge starter battery via the 1 A output of MultiPlus 500 VA - 1600 VA ?
The car (the new VW multivan) has a smart alternator and measures current flow from/to the starter battery via the onboard shunt. So I'd assume it will just "see" the inflow current and deal with it OK.
What do you think?
Thank you, David
alternator
kevgermany avatar image
kevgermany answered ·
If connected correctly and the multiplus is also a 12V unit, yes.
