lazza avatar image
lazza asked
Frequency shift- 3 phase
Hi
I've a couple of questions about frequency shift for a 3-phase Off-gird system:
  • Does the frequency shift in the Victron Quattros work in a 3 phase setup?
  • Can 3x Fronius single phase inverters work with this system, ie. 1 on each phase?
Thanks
Lazza
3 phase
Paul B avatar image
Paul B answered ·
Yes to both your questions.
Of course, the 3 phase setup must be confused correctly as per victrons standard 3 phase setup and the correct assistant settings installed
