joaquin avatar image
joaquin asked
Venus GX power supply fuse specs and dimensions
I understand this fuse should be 3.15 A, slow blow. I'm connected to a 48 V battery bank to supply power to my Venus GX . I'd like to have on hand some spare fuses and can't find a 48 V, 3.15 A fuse.
Can I use a 120 V, 3.15 A fuse?
What size (dimensions) should the fuse be (5mm x 20mm)?
thanks
Joaquin
Venus GX - VGX
Alexandra avatar image
Alexandra answered ·
@Joaquin
Yes, it is 5mm x 20mm in dimension.
They are not in the habit of blowing. Unless you might be in the habit of connecting and disconnecting?
Technically the 120v /250v ones are ok.
joaquin avatar image joaquin commented ·
Alexandra, many thanks
