Discovered a new issue. My low level setting for inverter is set for 10.5 volts, but is shutting down at 11.4? My victron shunt is reading 11.4 volt @ 75% battery and shuts down. Help!
11.4v is definitely not 75% SOC.
What you might find is underload the battery voltage is lower.
Are you using ESS at all?
This is happen during dry camping and a compressor was plugged into RV at about 2:00am. The inverter would not turn back on even when victron battery shunt displayed 11.4 volts.
As far as ESS, I have 700 watt solar on top of RV used with victron MTTP charge controller. Battery bank is (4) 100ah 12 volt lithium batteries.
Also, after I turned ff the compressor, my shunt was reading 11.4 volts-that would be with virtually no load.
ESS isn't intended for mobile use.
What is the restart value programmed onto the inverter?
You will still need to address the SOC issue. Do you have a shunt?
Inverter is set to turn off at 10.5vdc.
Yes, I have a shunt installed
I feel I have answered these questions in my original post. If not, please elaborate.
I read the system turned off at 10.5v I was asking what it is programmed to do. Expecially the restart value.
And that at 11.5v the battery cannot possibly be at 75% SOC.
What batteries do you have lithium or lead acid?
40 People are following this question.
