hansgeorgk avatar image
hansgeorgk asked
Relay not available
I would like to use Relay function of my EasySolar II GX. But it is not showing up in the Console
Screenshot of my Easysolar II GX
I have another System with Venus OS running Raspberry - there the Relay is shown on the console
What am I missing in the Easysloar II GX setup?
thanks and Happy New Year
HG
Multiplus-IIEasySolar All-in-One
Rob Duthie avatar image
Rob Duthie answered ·
Hi
It does not have one, only in the VE config setup only i believe that is the limitation with the GX easy solar units, The raspi does and can be used, that is why i dont install the GX multiplus units due to limitations in certian area of relay control etc.
Regards
Rob D
NZ
Victron Raspi Hat.pdf
victron-raspi-hat.pdf (737.1 KiB)
hansgeorgk answered ·
ah - bad luck :-(
so the documentation:
8.5.2. Programmable relay
The product is equipped with a programmable relay. The relay can be programmed for different applications, for example as a starter relay.
is referring to the virtual switch/Assistant function?
Which seems has very limited functionality compared to the relay function I see on my raspy ...
so one option could be to implement the nice Generator start/stop function using node red?bildschirmfoto-2024-01-05-um-215451.png
At least to some extend ...
Any other ideas?
Hi
As its built GX device it is limited to less functions like the Cerbo or raspi units, yes you have to use VE configure for the relay control assistant functions to change function painfull as it seems.
Regards
Rob D
NZ
