Paul de C. avatar image
Paul de C. asked
Daly BMS 400amp with Multiplus-ii 48/5000
Dear Victron Forum
I have a Daly 400amper bms (I wanted 300 but they didn't have in stock). Connected to a Multiplus-ii 48/5000. I have 16*lipo accus of 306ah.
The Daly is working via Bluetooth on my mobile phone. I have set the protocol type on the app to "victron energy"
The Daly b- cables go to a victron shunt then to a busbar then to the multiplus
There is a positive cable from the positive of the "final" accu, to a main switch then to a 300amper fuse, then to a busbar, before going to the positive terminal of the multiplus.
The ac out 1 goes to the fuse box.
When I turn on the multiplus the "inverter on" lamp flashes as well as the "charger absorption" light. They blink alternatively.
What must I do to get the multiplus and bms to communicate?
There are two "ve.bus" connections on the multiplus-ii and the Daly bms has 2* can wires, 2*485 wires and a ground cable.
Please help as I am meant to go travelling with my truck next week and I need to get the electricity fixed.
Thanks Paul, Netherlands
Multiplus-IIBMS
Mike Dorsett avatar image
Mike Dorsett answered ·
You need a Cerbo or GX device to connect the data from the bms to the Multiplus.
mjs500 avatar image
mjs500 answered ·
multiplus-II can not be Connected to a Daly Bms directiy you require Cam in put so you will need a Cerbo or GX device
Paul de C. answered ·
Hey, thanks for your answer.
So, if I got a cerbo, I would connect the ve.bus of the multiplus into the cerbo.
Then I would connect the Daly bms also into the cerbo. But how would I connect the Daly into the cerbo? There are 5 cables. 2 can cables labelled "h" and "l" , 2 rs485 cables labelled "a" and "b" and 1 "ground" cable.
Then should it work?
mjs500 avatar image
mjs500 answered ·
Victron side is Pin7 = CAN-H, Pin8 = CAN-L and Pin3 = GND RJ45 plug type
You need to used Can
Connect the ve.bus from the multiplus II into the cerbo VE bus port and connect Daly bms Can out put in cerbo VE-can port
you will need to setup can port in the GX device soft ware
