peter26 avatar image
peter26 asked
Easysolar 2 PUK Code ?
Hi, I have an Easysolar-ll but am unable to access Victron Connect with my Android mobi via Bluetooth. None of the default PIN numbers are accepted. The only option is to reset the PIN using a PUK ( ? ) Code. I can have the units WIFI Key, ETH MAC and VRM ID Codes but no sign of a PUK Code. Any clues before I pull my remaining hair out ?
Bluetooth
Alexandra avatar image
Alexandra answered ·
@Peter26
What exactly are you trying to connect to?
The mppt? The GX? or The Inverter?
peter26 answered ·
Hi Alexandra,
I'm trying to connect to the MPPT of the EasySolar II unit via Bluetooth.
All of the suggested default PINs ( 000000, 0000, 1233 ) are not accepted. The next offered option is to reset the PIN with a PUK Code. I have looked behind the lower grill and found a label with Serial Number, WIFI KEY, ETH MAC and VRM ID but no sign of a PUK key.
Jona Aal avatar image
Jona Aal answered ·
Any news on this one?
@Jona Aal Not all easy solar's have Smartsolar mppt's. Some have Bluesolar mppt's, ie no bluetooth. Check which model mppt is fitted.
You can Connect & Configure Remotely with VictronConnect via VRM.
Jona Aal answered ·
It is definitely a smart solar, bluetooth is available, just that the inverter is used and the password has been changed form the standard
@Jona Aal You can reset the bluetooth pin with the PUK code found on the side of the mppt.
Do be very careful.
Jona Aal avatar image Jona Aal klim8skeptic ♦ commented ·
@klim8skeptic
Thanks for youre help here, I got a bit muddled with the product names.
We have an Easysolar2GX (not smartsolar) which has the mppt built in.
We need the PUK code which apparently is not on a label but is in one of the bags with cables when the product is newly in the packaging.
I have asked our local sales rep to check the database with the SN and PN and let me know the PUK for our inverter.
Cheers,
Jona
