psdejager avatar image
psdejager asked
Lynx Shunt stays in the standard of 200 AH..
LiFePO4 Batterij 1630AH (6x 48V 272AH) with each it's own BMS
I have used the virctonconnect app and set the Lunx Shunt to 1632AH
Lynx Shunt is Still in the standard of 200 AH because it gives a low battery with @53Volts left...
Why will it not use the 1632 instead of the standard 200AH?!?
Where do I change this setting?
lynx shunt
pwfarnell avatar image
pwfarnell answered ·
The Lynx shunt will need a full charge cycle to set to 100% before it will work properly. Post some screenshots of your settings from VE connect so we can see if there is anything wrong.
psdejager answered ·
I pressed the synchroniseren it was full
pwfarnell avatar image pwfarnell commented ·
The settings have remembered the correct capacity. Now it is set to 100% it should work OK from now on. The only thing that might be too low is the tail current (Staartsstroom) if your batteries stop charging before this reduces to 1% (16.4A). You may need to increase this to ensure that the Lynx hunt auto resets to 100%. Check what your actual tail current is when the batteries stop charging.
Lynx Shunt VE Can online manual
