Chris avatar image
Chris asked
ve.bus multi control (not digital)
Hi All
I have just installed a Quattro 24/5000 with 26****** chipset. it is connected to Cerbo GX and its showing on VRM and locally but i would like to utilise the old VE.Bus Multi Control.
When i plug the UTP cable in to the 2nd RJ45 on the Quattro the Multi Control will not work, if I unplug the Cerbo GX the Multi Control works ok. My question is if and how to connect both.
It would be really helpful to able to have control from the wheelhouse of current draw when engine is running with our 7KVA 220v alternator.
Can someone please explain how i could achieve this type of setup
as ever, many thanks
Digital Multi Control
Chris avatar image Chris commented ·
I should add that this Multi Control was on our old 18***** Phoenix Multi Plus
