Gregory Cavanagh avatar image
Gregory Cavanagh asked
Bluetooth on new style Multiplus
Hello everyone,
Does the bluetooth module work with the new style multiplus? There is nothing in the multiplus manual stating it can be done,
Also the "new style" don't seem to be in Victronconnect unless it is just using the same product images as the old one?
Another question is help section in the app states no settings can be adjusted via Victronconnect and must be done via VE configure, however when you load a demo Multiplus alot of settings can be changed? is that only for demo items?
Thanks,
MultiPlus Quattro Inverter ChargerBluetooth
Guy Stewart (Victron Community Manager) answered ยท
Hi @Gregory Cavanagh,
This information may change in the future, so please check these documents for the latest info:
http://docs.victronenergy.com/victronconnect-vebus.html
Currently:
The VEBus Smart Dongle bluetooth module can only be used with the MultiPlus to provide "Status Mode" information.
If you want to access Settings Mode, that requires the MK3-USB interface adapter.
Some of the product images are not perfect in VictronConnect, please report exactly which ones aren't right and we will fix them up.
Please read the limitation section of the VEbus Victron Connect manual here for information about which settings are available in VictronConnect, and which require VEConfigure - https://docs.victronenergy.com/victronconnect-vebus.html#limitations
Gregory Cavanagh avatar image Gregory Cavanagh commented ยท
As for the pictures, shouldn't these ones below
Look something like these "new styles" ones? i think the 12/500 12/800 and 12/1200 are affected
0 Likes 0 ยท
