Jaad Jorio avatar image
Jaad Jorio asked
Connected panel to PWM controller before batteries
I disconnected my batteries from my DUO 20A controller, and reconnected them, because I had to move them.
In the meantime, the solar panel was always connected to the controller.
Could I have broken something ? As the manual says, always connect batteries first ...
Thanks,
Jaad
error
JohnC avatar image
JohnC answered ·
Hi Jaad. I suspect most of us have done this before inadvertently, usually with no issue.
It's possible with some cc's (maybe older ones) that they may pick up a different battery V base and charge to a different level. Just check that hasn't happened.
It's just good practice to do it that way. Batt buffering, spike reduction, etc.
Is it not working?
Jaad Jorio answered ·
Hi John,
Thanks for your feedback.
Good to know I am not alone !
It is actually working, I was in doubt about the behavior of the controller, not charging, but this is because the batteries were full .... so easy fixing of no problem.
After I realized I connected the panels first, I redid the connecting again, starting from the batteries this time, to make sure the V is set to 12V.
Thanks !
