Eric avatar image
Eric asked
ac coupled solar output on vrm and reports
I have an ESS Setup with ac coupled solar. I also have a multiplus 2 with 11kwh battery to feed house loads.
I have Home Assistant gathering solar output data and feeding it to my raspberry pi running Venusos using the venus-os_dbus_mqtt_pv addon.
The solar appears in the main VRM panel but not the daily graph lower down. Neither are the values recorded for the kwh output reports.
Is there anyway to get the kwh of solar recorded ?
Eric
VRM
