Trevor Bird avatar image
Trevor Bird asked
CerboGX Remote "Enable on LAN" stops VRM Remote Console working
Hello, Today I was on a boat that had the CerboGX swapped for a new one. I was setting it up for another company some distance away. We updated to latest firmware (V3.13). During the initital setup I was enabling remote access and in the "Remote Console" menu checked the "Enable on LAN" box for no particular reason. We didnt want to use the local LAN for the Remote function but thought it can't hurt.
On my mobile phone I accessed the VRM using the Safari browser, but could not access the remote console on the phone. Neither could the Tech support at the far end.
I disabled "Enable on LAN", rebooted and the mobile phone access to the Remote Console worked as it should.
Is this a normal consequence of checking "Enable on LAN"? I have tried to see reference to this in the forum but didn't find this exact issue. I dont see any indication of this side effect of enabling "Enable on LAN" and wonder if that really was the cause or rebooting resolved some other issue?
Any thoughts welcomed.
Trevor
remote console
Alexandra avatar image
Alexandra answered ·
@Trevor Bird
No, it is not normal unless a device is accessing it. I have both enabled on all systems.
I sometimes find remote support and I have a squabble over who has it open and someone gets booted off since it can only be open in one instance.
What was the error message when that happened?
Trevor Bird avatar image Trevor Bird commented ·
@Alexandra
No error message. The remote Console simply did not work. I couldn't get it to show the console on my phone.
I thought it was unusual but didnt have time to backtrack and try to find the real reason.
ngknick avatar image ngknick Trevor Bird commented ·
Did you ever find a solution for this? I think I'm having the same issue. Someone mentioned resetting the device may fix it but I don't feel like putting all of the settings back in
