Jason Lau avatar image
Jason Lau asked
Advice on replacing Redarc BCDC1225 with Victron
Hi! I have a new Jeep build, and currently I'm using Redarc BCDC1225 as a DC-to-DC battery charger. From my main jeep battery: power runs through a Blue Sea Battery Cutoff Switch, then to the DC input of the Redarc DCDC controller. The output goes to two 30ah Eco-Worthy LifePO4 batteries connected in parallel, and that's used to power dometic fridge and other electronics. The other input to the redarc is for solar. Redarc is fine, but it's not easy to service, and I'm more use to Victron. I *think* I need to get Victron Orion-tr Smart 12/12v 10a DC DC charger, plus Victron SmartSolar MPPT 75/15 for the solar input. Does that sound about right? Redarc is fine, but I miss having BT connectivity to monitor inputs/outputs.
MPPT SmartSolarorion-tr smart
