Michelle Konzack avatar image
Michelle Konzack asked
3-phase EnergyMeter with Ehternet
Good day,
comming spring I will increase the power of my DC coupled Solarpower to 10kWp and add also a Fronius Primo 8.2-1 with additional 8,6kWp which also require a second MultiPlus-II 24/5000.
However, In the summer, this system produce easily 150kWh and my Batteries have only 70kWh + 175kWh.
However, I got an offer for a (now) nearby Grid connection.
Since I own the Land where the 75kVA transfornator is installed, I want to install an additional Fronius Symo 8.2-3 with 8.6kWp of solar directly on the side of the transformator. The 250m Aluminium cable AXPK 4G2 I will install my self.
However, coming from the transformator into the MAIN fusebox and then to my JÄjunktion box for the Fronius Symo and the AXPK cable, I need a 3-phase Energy meter with ethernet (250m minimum) which will be realised using Media-Converter and a Multimode FiberOptic cable which I have spare laying around.
Can someone recommend me the right EnergyMeter please?
(of course, must work with the CerboGX)
It must support the 8,2kW from the Fronius Symo 8.2-3 and on one phase (will be selected by the Grid Provider Elektrilevi) 7,6kW.
Which is roughly 50A per phase.
Energy Meter
dirk-s avatar image
dirk-s answered ·
Please have a look at www.elgris.de .
They have a multi protocol smart meter with 2 Modbus and 1 Ethernet connection. Protocol for Fronius is also supported. Today you get 15% Nicolaus off with the code elgris15.
I ordered one today because I want to replace the EM540 and the SolarEdge Smart Meter. It can handle both protocols in parallel.
The protocol for EM24 also supports modbus TCP.
Michelle Konzack answered ·
This exactly what I was searching for.
Unfortunately I can not buy so fast.
