old-joe avatar image
old-joe asked
No load current showing with VE Direct Smart dongle and Blue Solar 75/15 MPPT
Have just installed a VE Direct Smart dongle into my RV and connected to a Blue Solar 75/15 MPPT charger/regulator, charging an AGM battery. Prior to this addition, the load circuit was tapped from the battery terminals. The installation also includes a DC-DC charger (not Victron) and all B negatives were commoned at the DC-DC charger.
I have now reconnected the load circuit B+ to the load B+ terminal at the Blue Solar module. I understand that the B- battery and B- load terminals in the Blue Solar module are common.
The load works fine i.e with load B+ derived from the Blue Solar load B+ and commoned B negs.
I cannot read any load current on the app! Why is this so?
VE.Direct
old-joe answered ·
I am answering my own question.
Despite reading a contributor's advice that all control/metering is done on the B+ (high) side and the B negs were common, therefore it was OK to operate with only the pos load circuit connected to the output side B+ and connect the load circuit neg to B- This is not true.
I have now separated the B negs from a common connection and run the load circuit as a completely isolated pair (without any gnd reference) and all is good.
