I installed a new heat pump and am pretty interested about the consumption of this heat pump. Is it possible to add an additional AC Load somewhere here? (of course with an additional measurement device).
Thanks!
Timo
Thanks!
Timo
@techmuc you can add 'load' meters to your system, which will provide the meter data in the advanced section of VRM as a widget. It wont show that load as a separate items in the VRM dashboard. 2nd option is to have your heat pump on the AC-Out of the Multiplus. This will show the consumed power and the total energy used in a set period. 3rd option is to access the settings of your heat pump, as nearly all heat pumps provide power consumption. I have a Mitsubishi Ecodan, of which I can see the energy consumed in the settings and I can also bring that data into Node Red from the MELCLoud API.
Thanks a lot for your ideas.
Option a) I will give it a try.. I have a shelly already so I can write a custom meter to integrate it into venus.. Do you know if there will be at least an own widget for it?
Option 2) my heat pump has three phases and I only have a one phase mp system.. Would be a very good idea.. I will investigate if I can manipulate the critical load values via mqtt / custom drivers somehow..
Option c) that I have already implemented. I just like to have one chart on lead, and honestly the vrm / victron graphics are the nicest visually :)
Thanks again @Jason - UK
59 People are following this question.
