bent avatar image
bent asked
BUCK-BOOST in parallel
I have two Buck-Boost running in parallel one connected to each engine, and on the output side connected in parallel. All parameters are set to the same value for both converters. Only one of them will convert when both engine running. They both work fine, not depending of which engine running, but with both engine running one of them will torn off. Any idea what can be wrong, or will they not work in parallel.
dc isolators in parralell system
