oleksii avatar image
oleksii asked
VRM Battery is showing discharging when in fact it is charging.
Hi, I have little problem. My system has 3 Quattro 15kWA, 3 450\200 mppt and 8psc LiFePo4 batteries (40kWh). I see on the dashboard of the VRM portal both battery and inverter show "Discharging" and -15000 W and the dots are moving away from the battery. In the Remote Console status display the dots are moving towards the battery but also -15000W. I see this problem only with a big power of charging (300A). When current are not high vrm shows correct info (+4000W). Do you have any ideas?
VRM
