yotamota avatar image
yotamota asked
Ve Direct to control 12v inverter shut off
Hello folks
I have a 1000w 12v PSW samlex inverter. I am looking to shut off the inverter using the "remote" switch on the front of the inverter. I bought the tx output cable thinking it operated at 12v. Well turns out it doesn't. Can anyone help me find the correct way to shut the inverter off?
Part of me wants to try the figure on the left. However I am not sure if it will shut off the inverter or not. I am wanting to use the "load output" setting to control a Low voltage disconnect.
I think this inverter is intended for service trucks, where it can be connected to an ignition source to turn the inverter on.
Thank you
Edit
So I just tried the signal / - input. The inverter beeped the whole time. I suspect its lower than 10v so it thinks there is an issue...
VE.Direct
@yotamota
Do you have the inverter to use/test?
If you do to check the figure on the left you just put a jumper in to check.
It would be helpful to know what Victron components you have chosen so we can help more.
yotamota avatar image yotamota Alexandra ♦ commented ·
smart solar 100/50amp.
yes i do have the inverter to try
