anibal-solar avatar image
anibal-solar asked
Victron Inverter whitout solar panels
Hello, I would like to confirm the answer to the following question. Is it possible to connect a three-phase inverter system without solar panels, which is only responsible for keeping the batteries charged with the electricity supplies from the electrical grid?
Thank you all
batterymultiple inverters
Alexandra avatar image
Alexandra answered ·
@Anibal Solar
Absolutely it is. We have quite a few in the field whose only use is peak shaving. No solar.
anibal-solar avatar image anibal-solar commented ·
thank you!! I needed to confirm it with someone who had already installed it, by the way, what model of invertir do you use?
Alexandra avatar image Alexandra ♦ anibal-solar commented ·
We have pretty much installed all of the Victron range of inverters at one point.
You may be required to use Multiplus 2. It depends on where you live and the grid code regulations as well as the size inverters you require.
