David Channin avatar image
David Channin asked
Strange VRM behavior not showing additional shunts in the device list
I have two Victron SmartShunt 500A/50mV (Standard version) shunts in my system. One is the usual shunt between battery negative and the system. The second is set up as a DC Meter between the battery negative and (the negative of) an Orion-Tr 48/12-30A DC-DC converter.
Both shunts appear on Cerbo GX and data appears to be correct.
Both shunts show up on the device list of my VRM installation.
The main battery shunt but not the DC meter shunt shows up on the VRM dashboard.
The main shunt has a number of widgets available in VRM.
The second, DC Meter shunt DOES NOT SHOW UP on the widgets list. Yet, I can create a custom widget with it's data.
Question 1: Why doesn't the DC meter shunt show up on the VRM dashboard
Question 2: Why aren't default widgets available for the second shunt?
VRMwidget vrm
