Hello is it possible for the AC Loads to show output voltage again , i am guessing there’s a bug since the area has been blank for sometime now and i am pretty sure it was showing voltage prior to this . Thank you
Hi @CM,
This voltage would always be the voltage setting (e.g 230V) of the inverter or the AC input voltage (which is shown in AC-input when connected).
Why would you need to see it on AC-output?
59 People are following this question.
